Thread: syntax for post build actions in project/settings
    28.11.2017
    19
    Default syntax for post build actions in project/settings
    hi
    what is the syntax to use for post build actions in project/settings
    I want to copy some files from one directorie to another
    thanks
    06.01.2016
    Lächeln Re: syntax for post build actions in project/settings
    Quote Originally Posted by mos89 View Post
    hi
    thanks
    Hi Mos89,
    The syntax is the same than the one in the command line prompt of windows.
    For example, you can type only "script.bat" and it will run the script.bat file located in the folder of the project.
    Or you can type "copy APPLI.XTI t5.cod" for copying a file
    You can also use special alias like $(P) that will be replaced by the path of the project directory, $(V) for the version of the project, and $(S) for the path of the install folder of Straton
  1. Zenon 7.20 SP0 build 17678 vs build 20554
    By sdolnyy in forum zenon Service Engine Supervisor
    Last Post: 18th December 2017, 21:50
  2. Report Syntax
    By synergyautomation in forum zenon Service Engine Supervisor
    Last Post: 13th April 2015, 09:36
  3. Syntax for referencing values
    By bsneddon in forum zenon Service Engine Supervisor
    Last Post: 12th May 2014, 11:00
  4. Demo on making comments (Post-It) on elements
    By herberto in forum zenon Service Engine Supervisor
    Last Post: 25th June 2010, 12:05
