Thread: Windows driver communication problems
    06.02.2012
    75
    Ausrufezeichen Windows driver communication problems
    Dear Forum-Community,
    Due to major security leaks in Intel and AMD processors, Microsoft and other software / hardware vendors released security updates at the beginning of the year 2018. An issue in these updates leads to problems with zenon. The effect is a known issue in several Windows updates.
    After applying one or several of these updates, various communication issues may occur. After a detailed analysis, we can verify that the issues recognized are based on the January 3rd security updates for various Microsoft Windows versions.
    COPA-DATA has generated a ticket at Microsoft Tech Support in order to coordinate activities and is urging on the case with high priority. Microsoft is working on a resolution and we are waiting for the Windows updates that will fix these issues. Any new information will be communicated as soon as possible.
    Download the full Tech Announcement from our COPA-DATA Homepage and don't hesitate to get in touch for further information.
    Thank you very much!
    Your COPA-DATA Team.
    19.08.2019
    Default Re: Windows driver communication problems
    Dear COPA-DATA Team,
    have you received feedback on your ticket to Microsoft?
    Or can you give us any indication that might help us to identify these driver problems?
    We have driver stability issues with current versions of Windows Server 2016.
    Problems that do not occur with Windows 10 LTS Versions from 2016.
    We are using Zenon 8.0 Build 60603.
    06.02.2012
    75
    Quote Originally Posted by MarkusL View Post
    Hi Markus,
    the Problem was fixed in several zenon versions, including zenon 8.00. The fix is included in build 44055. As you're using build 60603, the fix is included in your current version.
    I would suggest that you reach out to your local support department to let them have a closer look at the behavior.
    The issue might come from somewhere else.
    Xandi
    08.11.2021
    Driver Support/knowledgebase/ Fix Device Driver Problems in Windows Fix Device Driver Problems in Windows If you are experiencing buggy hardware in your computer, there’s a good chance you are having device driver problems. Most device driver problems on Windows are caused by missing, corrupted or outdated drivers. It’s just one of the many reasons you should keep your device drivers up to date.
    08.11.2021
    Quote Originally Posted by xandit View Post
    You are doing well keep it up
  1. Windows driver communication problems
    By xandit in forum Drivers
    Last Post: 11th January 2018, 17:36
  2. Communication problems with Logix ODVA Driver
    By ManuelaGomes in forum Drivers
    Last Post: 12th May 2017, 09:11
  3. Communication and CPU - Power Problems
    By marcel.widmer in forum Engineering Studio & Service Engine (former zenon Editor & Runtime)
    Last Post: 19th September 2014, 10:49
  4. IEC60870 Driver Communication Status
    By knubla in forum Drivers
    Last Post: 29th November 2012, 13:32
  5. Client - Server communication problems
    By dragosmoss in forum zenon Network
    Last Post: 13th May 2009, 14:38
