Thread: About Runtime License
    30.03.2017
    33
    Default About Runtime License
    Dear friends,
    If I have a Zenon Energy Server License installed in a computer and I connect a monitor to it, i can see the HMI (in local mode), because server license already includes runtime license inside. That is right? or we need to buy also a Client License? (I think I only need a Client License if i see the HMI from a workstation connected to one or two servers in the network).
    Thanks in advance for your support.
    Jose Luis Torres
    816
    Default Re: About Runtime License
    On zenon Network Server (and Standby) you has access to all functionality of your projects.
    Anyway, for performance and security reasons, i would rather propose to keep Server machines out of direct access of operators; so to add Network Clients on additional workstations.
    30.03.2017
    33
    Thank you for your quickly response.
    So if I buy a server license and also a client lincese, I can use the HMI (runtime) locally (with a monitor, keyboard and mouse connected directly to the server computer) and remotely from a workstation in the network at the same time (two HMIs, obviously local monitor will be use only in exception cases)?.
    Also, for editing its not enough server or client license, I need an Editor License, right?.
    30.03.2017
    33
  1. Which License do I need?
    By EdgyUsername in forum zenon Supervisor
    Last Post: 27th July 2016, 09:36
  2. Zenon License
    By navaneet in forum Editor and Runtime Setup
    Last Post: 17th December 2014, 10:09
  3. do i need a new license in zenOn7?
    Last Post: 23rd May 2012, 08:37
  4. License
    Last Post: 25th January 2012, 00:46
  5. Client license
    By janlyndon in forum zenon Operator
    Last Post: 12th May 2010, 12:54
