Thread: K5Srv32.exe error
    10.05.2017
    68
    Frage K5Srv32.exe error
    While I am opening Straton in Zenon development software, I am getting an error 'Registering K5Srv32.exe failed'
    What could be the problem.? Please suggest.
    08.12.2015
    39
    Default Re: K5Srv32.exe error
    I think this problemn occurs because of missing DLLs.
    In order to see to which DLLs the K5Srv32.exe file is linked, you can use the "Dependancy Walker" tool (also called DEPENDS)
    http://dependencywalker.com/
    Just launch the tool, then open the K5Srv32.exe file with it (it should be, for example for the 7.60, in C:\Program Files (x86)\COPA-DATA\zenon 7.60 SP0)
    If missing DLLs are marked in yellow, this should not be a problem, but in your case you will probably see missing DLLs marked in red.
    For example, if MFC140U.dll is missing, you have to install the Microsoft Visual Studio C++ Redistributable 2015.
    All the Redistributables needed for your zenon version are on the zenon CD > Setup > SetupPrerequisites
    Have a nice day and an happy new year!
    Anthony
  1. zenon_startup.exe - System Error
    By arshad30ali in forum Editor and Runtime Setup
    Last Post: 1st February 2018, 12:44
  2. iec850.exe error
    By diemon in forum zenon Energy Edition
    Last Post: 16th September 2015, 15:01
  3. iec850.exe error
    By diemon in forum Drivers
  4. zenkeyblock.exe
    Last Post: 25th February 2010, 01:04
  5. Replies: 0
    Last Post: 14th November 2007, 13:39
