Thread: Zenon Screen switching functionality stops working
    Ausrufezeichen Zenon Screen switching functionality stops working
    Hello COPADATA Support,
    I am currently evaluating Copadata's Zenon software version 7.50. In that, I am exporting data in Excel format using "Report Export/Print" function. I am executing this function at every 30 secs.
    But issue is, after continuous running of few hours (12-14 hours roughly) zenon's screen switching function stops working and I cannot switch the screen. But exporting of data in Excel files keep running in background.
    I checked diagnosis viewer's file as well. It shows error as "GDI objects exceeded level to 9999". Once it reaches to 9999, zenon gets hang.
    Can you please tell me why is this happening?
    I checked this with Windows 7 64 Bit, Windows 8 64 Bit and Windows 10 64 Bit.
    I tried same in Zenon 7.60 and same issue is there too.
    Please give me solution for this.
    Attached Files Attached Files
    Daumen runter Re: Zenon Screen switching functionality stops working
    Hello Copadata Team,
    Can I expect reply from you or not?
    15.11.2016
    87
    Default Re: Zenon Screen switching functionality stops working
    Please forward this inquiry to your local Support.
    In your case: support.cee@copadata.com
    Please note that a forum-post is not guaranteed to give you an answer.
    BR,
    Georg
  1. Zenon 7.0 ZenWorkspace.vba not working in fresh installed Windows 7 32 bit PC
    By kamalikasamanta in forum Editor and Runtime Setup
    Last Post: 18th August 2016, 10:09
  2. Language Switching DIALOGKBD
    By EdgyUsername in forum zenon Supervisor
    Last Post: 27th July 2016, 08:35
  3. automatic switching (substation automation)
    By elsoportar in forum zenon Energy Edition
    Last Post: 14th April 2015, 12:20
  4. Switching variables in Report
    By a.oprean in forum zenon Supervisor
    Last Post: 15th January 2013, 02:05
  5. Questions regarding functionality
    By mightor in forum zenon Supervisor
    Last Post: 16th March 2012, 16:00
