Thread: system table version change possible?
    29.04.2014
    28
    Default system table version change possible?
    Hi Team,
    I developed a project in 7.5 and I want to use it in a 7.11 installed machine?
    Is it possible? I noticed those project when i open in 7.11, the system table version is 7.5 .
    Could it be possible to change that version back to 7.11 and can be used in 7.11?
    please support
    thanks
    regards
    sarav
    09.03.2011
    44
    Default Re: system table version change possible?
    Hi sarav,
    To use a 7.50 project in a 7.11 RT, you need to create the RT files for 7.11.
    You can do that in the zenon Editor: select the project --> go to its properties "General --> Create Runtime files for:" and, in the combobox, select the version you want, in this case, 7.11 SP0.
    Then, compile and, when you start the 7.11 RT, select the files for the project you just converted.
    You can find more information on the help: "Runtime --> Runtime files"
    Steffi
    29.04.2014
    28
    Thanks Steffi for the response.
    Now I want to clarify a new case,
    I have a machine A with 7.5 & 7.11 installed & machine B with 7.11 only.
    I took a project from machine B & used in A in 7.11, its asking for "are you like to use new version of 7.11 than older" I clicked yes & developed project further in machine A.
    Now if i want to use the same 7.11 project from A to B - is it possible, because I am unable to do so.
    Actually this was my issue. Could you suggest any solution?
  1. creating a table in zenon
    By lmucha in forum Engineering Studio & Service Engine (former zenon Editor & Runtime)
    Last Post: 1st June 2017, 10:31
  2. creating a table in zenon
    By lmucha in forum VSTA
    Last Post: 24th April 2017, 10:05
  3. how to change build version
    By tanveerali in forum zenon Energy Edition
    Last Post: 26th May 2015, 09:58
  4. Recipe table
    By scadavmesnik in forum Engineering Studio & Service Engine (former zenon Editor & Runtime)
    Last Post: 6th August 2012, 23:20
  5. Advantage of ZenOn Energy version versus Standard version?
    By lephis in forum zenon Energy Edition
    Last Post: 23rd June 2011, 23:54
