Thread: Too many I/O variables declared ERROR
    10.05.2017
    65
    Frage Too many I/O variables declared ERROR
    I have around 1,50,000 variables in Straton. out of which 80,000 variables are Global variables. My licence is of unlimited tags but still, I am facing the above-mentioned Error while compiling the Straton Project.
    Please suggest what could be the problem.
    08.12.2015
    39
    Default Re: Too many I/O variables declared ERROR
    There is an internal limitation for the number of declared variables in straton Editor.
    The first thing that you can try is to set the followimg option, doing a right click on your project:
    Settings > General > Complex variables in a separate segment > Yes
    In order to reduce the number of variables, you can also merge them in an array.
    Here is a detailed description, valid for Straton 9.1 (for older and newer versions, it should be the same)
    If complex variables option is checked :
    Max 65534 single variable of type BOOL, SINT, USINT or BYTE declared one by one
    Max 65534 single variable of type INT, UINT or WORD declared one by one
    Max 65534 single variable of type REAL, DINT, UDINT or DWORD declared one by one
    Max 65534 single variable of type LREAL, LINT, ULINT or LWORD declared one by one
    Up to 4GB of arrays, structures FB instances and combination of them
    Anthony
  1. Variables association error in child project
    By davide.galigani in forum VBA
    Last Post: 28th June 2012, 08:57
  2. PLC Variables and Internal Variables
    By madphilly in forum Drivers
    Last Post: 4th June 2008, 06:59
