Showing results 1 to 8 of 8
Thread: How to open PDF file in zenon run time
    Default How to open PDF file in zenon run time
    I need to open manual (PDF file) for my instruments in Zenon screen..
    Please let me know how can I do this?
    15.01.2016
    73
    Default Re: How to open PDF file in zenon run time
    Hello
    Yes there is a simple posibility to use PDF in zenon just create a screen from type HTML and create a screenswitch funktion when creating the SW funktion you can enter in the URL the path of your PDF.
    Hint: dont use "" because it does not work.
    Best regards
    Tobias Ritschel
    Step 1 : New Functions
    Step 2: Windows > Start Program
    Step 3: Name= "PDF reader exe file location" & Parameter = "you file location"
    Step 4: Create button/image object and link your function with it
    Follow below image step
    17.01.2018
    5
    Hello, I've got a pretty similar question, but I need to open PDF files in Zenon WebClient. I store PDF file on the runtime machine.
    Now I want to open it in Zenon Web Client - ScreenType HTML.
    How my URL adress should look like? Do I need to install PDF viewer on Runtime machine?
    15.11.2016
    94
    Hello michalt,
    1. Do I need to install PDF viewer on Runtime machine?
    -> The Client PC needs to be able to view PDF in the normal browser (PDF Plugin).
    -> Otherwise it would not work in the zenon HTML Screen.
    If that works then I suggest to include the PDFs into the IIS of the WebServer.
    - Locate a folder with the PDFs and set the Security: add user "Everyone" with read access.
    - in IIS go to the zenon and add a virtal directy with link to your manuals-folder.
    In zenon HTML screen they can then be accessed with https://WebServer-hostname/zenon/name created manual directory/name of pdf.pdf
    Hope that helps.
    BR,
    Georg
    06.07.2018
    I would suggest you don't need any extension to do so but third-party service allows to view pdf's. With Zenon 8 I use this one https://990-pf.pdffiller.com/ But it's a paid one. As well it doesn't work with Zenon perfectly depending on Windows version. I'm running it under the previous build and everything works pretty well but one of my clients tried to do so with the device where the latest april update has installed and it's quite unstable there
    10.05.2017
    65
    Frage Re: How to open PDF file in zenon run time
    Quote Originally Posted by ritschel93 View Post
    Hello
    Best regards
    Hello Team,
    While using HTML screen type to show PDF files in runtime, my pdf docs opens outside the runtime in Adobe reader. I want it to open inside Zenon HTML screen itself.3
    Please suggest
    Joel
    Dear Joel,
    Please find below settings for opening specific PDF and try in your system. It works
    Warm Regards
    Srikanth G
  1. Alarms in RUN-TIME
    By matteo.fabbri in forum VSTA
    Last Post: 8th March 2014, 17:38
  2. Changing user name at run time
    Last Post: 24th September 2013, 21:00
  3. Report Generator Run Time Text
    Last Post: 3rd September 2013, 14:44
  4. Replies: 1
  5. how to remove windows elements during run time
    Last Post: 25th May 2011, 23:28
