Thread: Import variables from TIA V14 to Zenon 7.60
    12.10.2016
    6
    Default Import variables from TIA V14 to Zenon 7.60
    how can i import variables from a TIA 14 project with zenon 7.60 build Build39532 since PLC.
    15.11.2016
    99
    Default Re: Import variables from TIA V14 to Zenon 7.60
    This feature was added after the 7.60 release.
    Please see this Knowledge Base entry:
    https://www.copadata.com/de/support-services/knowledge-base-faq/s7-15001200-driver-it-should-be-possible-to-sele-2251/
    There you can download the Build Update for your version.
    BR,
    Georg
    12.10.2016
    6
    I have download the release but i always the error message : TIA project cannot be loaded!
    TIA V14 SP1 update1
    07.02.2017
    9
    For TIA 14 is currently possible online browsing but only with TIA driver.
    For TIA 14 with combination with S7 tcp driver,  absolute addressing with the supported PLC types: S7 300, S7 400, is possible, no online or offline bruwsing currently for TIA14. S7 1200, S7 1500 works with S7-tcp driver with not optimized datablocks.
    We cannot guarantiee that TIA14Sp1 is compatible with 7.60 because it was released after the development cycle of 7.60.
    BR
    Tsvetelina
  1. Import variables from TIA V13 to Zenon 6.51
    By professor_hubert_farnsworth in forum zenon Operator
    Last Post: 14th November 2016, 14:16
  2. Replies: 3
    Last Post: 22nd August 2014, 10:13
  3. XML Import - Variables
    By abcd1234 in forum zenon Supervisor
    Last Post: 23rd December 2013, 17:00
  4. Import Variables
    Last Post: 4th August 2008, 12:33
  5. Help! I can not import my variables .dbf file
