Thread: Automatically build using the STRATON development environment
    10.11.2017
    Default Automatically build using the STRATON development environment
    I have a STRATON project (W5L and K5P files). I would like to automatically build the project so that I can check for errors. Is this possible using the automation interface or via the command line?
    I have the STRATON Development Environment which we use to create and edit the project.
    Thanks,
    Garret
    08.12.2015
    39
    Default Re: Automatically build using the STRATON development environment
    Hello Garret,
    You can do that using the K5B.exe
    You can find it in the folder where straton is installed (or in C:\Program Files (x86)\COPA-DATA\zenon 7.60 SP0, for example, if you are using zenon Logic)
    Open a command shell where the file is, then type
    ./K5B.exe
    It will show you the available options.
    If you want to build a project, you must use the 'Build' option (see the attached picture)
    Have a nice week,
    Anthony
    10.11.2017
    Thanks Anthony. That's exactly what I needed.
  1. Webserver in internet environment
    By joelprasad in forum Smart Server & Smart Client (former Webserver & Webclient)
    Last Post: 31st October 2017, 18:28
  2. Zenon 6.22 SP1 Build 0 and Zenon 6.22 SPS1 Build 17
    By doloemanuel in forum Engineering Studio & Service Engine
    Last Post: 26th September 2017, 16:50
  3. Different monitor resolutions on development and target machines
    By micko in forum zenon Service Engine Supervisor
    Last Post: 29th November 2010, 08:28
  4. automatically created limits
    By markclemens in forum zenon Service Engine Supervisor
    Last Post: 20th August 2007, 10:21
