Thread: How to change numeric display on round slider
    07.02.2014
    5
    Frage How to change numeric display on round slider
    Hello guys,
    I am using zenon v7.20 operator and created a CE project which has a round slider to show the angle of a press slider. I need to show the number "0/360" at the top and "180" at the bottom. However in the properties I only managed to configre the 0 at bottom and 180 at the top. Do you know how to change this?
    Claude Yin
    15.11.2016
    108
    Default Re: How to change numeric display on round slider
    Hello Yin,
    I tried this and was surprised that this is not allowed.
    The Start-angle and End-angle must be between 0 and 360.
    And the angle origin is always at the bottom.
    But by manually telling the element that is should show the scale from 180-540 it will show as you described.
    -> Although setting values via mouse drag does not work.
    I created a symbol (zipped).
    -> You can XML import this symbol in Project -> Screens -> Symbol library.
    Attention:
    Please use this with caution, since it uses unintended boundaries.
    BR,
    Georg
    07.02.2014
    5
    This works fine! Thanks a lot Georg!
    Quote Originally Posted by georgk View Post
    Hello Yin,
    Attention:
    BR,
    Georg
  1. Change the Variable linked to a "Numeric Value" or to a "Dynamic Text" in the Runtime.
    By hamiiiz in forum Engineering Studio & Service Engine (former zenon Editor & Runtime)
    Last Post: 13th March 2017, 13:51
  2. function ROUND in zenon Logic
    By ursulak in forum Engineering Studio Logic & Logic Service (former zenon Logic Workbench & Runtime)
    Last Post: 6th June 2016, 09:19
  3. Universal slider
    By jahidbagwan in forum Engineering Studio & Service Engine (former zenon Editor & Runtime)
    Last Post: 18th August 2014, 07:05
  4. Change Numeric display color on inactive
    By bsneddon in forum Engineering Studio & Service Engine (former zenon Editor & Runtime)
    Last Post: 6th May 2014, 07:02
  5. Extended trend - last day with round hours
    By jurijcadez in forum Engineering Studio & Service Engine (former zenon Editor & Runtime)
    Last Post: 30th January 2013, 11:26
