Thread: Not able to set up web client
    10.05.2017
    68
    Frage Not able to set up web client
    I am not able to set up web client from the index page http://www.publishingserver.com//zenon/index.htm. The browser shows "This page can’t be displayed ". Please suggest a solution. I have tried in IE, Chrome and Firefox. I have added it to the trusted site in IE too. Neither I am able to set up using the entry page.
    03.11.2015
    48
    Default Re: Not able to set up web client
    Quote Originally Posted by joelprasad View Post
    I am not able to set up web client from the index page http://www.publishingserver.com//zenon/index.htm. The browser shows "This page canít be displayed ". Please suggest a solution. I have tried in IE, Chrome and Firefox. I have added it to the trusted site in IE too. Neither I am able to set up using the entry page.
    Hi, if this error occurs,  it is most likely that your IIS is not running or the connection to your webserver can't be established. Either because of a firewall/network routing or because the IIS is not started.
    BR,
    Joris
    01.02.2017
    6
    Are You sure that address is fine because I see here 2 // after .com
    Did You turn off Your firewall?
    Did You set up correctly global_vars.js inside inetpub\wwwroot\zenon\config? (by that I mean all parameters needs to be written in capital letters)
    Hope that something will help, or that You already solved Your problems
    Damir
    10.05.2017
    68
    Quote Originally Posted by joris.l View Post
    BR,
    Joris
    I was not able to establish communication with the Webserver. Thank you for the suggestion.
  1. Web Client Error
    By yitlilee in forum Webserver / Webclient Setup
    Last Post: 24th February 2015, 20:33
  2. Web Client
    By gyu in forum Webserver/Webclient
    Last Post: 4th March 2014, 08:27
  3. zenon Web-Client 7 -> Web-Server 6.22 slow startup
  4. Web client subprojects error
    By jurijcadez in forum Webserver/Webclient
    Last Post: 17th May 2012, 23:34
  5. Web client VBA
    By jurijcadez in forum VBA
    Last Post: 15th May 2012, 14:43
