Showing results 1 to 8 of 8
Thread: Symbol Library
    19.10.2017
    6
    Default Symbol Library
    Hello all,
    I created a symbol in the symbol library and then used this symbol 10 times in screens.
    This is a button.
    A client asked to change the color of the button.
    So I changed the color of a symbol in the symbol library, but the color on the screens, where this symbol is used, didn't change accordingly to the new color ...
    How can I update the change in this symbol all over the project screens?
    Olesia.
    02.07.2014
    27
    Default Re: Symbol Library
    Hello Olesia,
    welcome to the Copa-Data forum!
    Have you saved the symbol after changing the color? Changes takes places after reedited symbol is saved. As well it is important that in this case we are using "link" from the symbol library instead of inserting symbol via holding CTRL.
    Best Regards,
    stani
    19.10.2017
    6
    Hello Stani,
    Thank you
    Saving the changes and F5 solved the issue.
    What do you by "As well it is important that in this case we are using "link" from the symbol library instead of inserting symbol via holding CTRL" ?
    02.07.2014
    27
    We have 2 possibilities while inserting the symbols from symbol library:
    1st is by drag and drop only - With this one, we will get only link inserted which means if we change the symbol from the symbol library, all other linked symbols will change as well...
    2nd is by drag and drop while holding the CTRL - With this one we will create a new instance of a symbol from the library, which means technically we will have a 2 different symbols which are looking the same but changing appearance of the one of them wont influence the other.
    I hope i help you out with solving the problem
    Best Regards,
    stani
    19.10.2017
    6
    Lächeln Re: Symbol Library
    Thank you Sani, your explanation was helpful.
    I am new to Zenon, so I know that my questions are still in a basic level :-)
    02.07.2014
    27
    You are welcome!
    I am glad that i can help...
    BR,
    stani
    15.01.2016
    87
    Idee Re: Symbol Library
    Hello Olesia
    If you new to zenon and want to have some usefull tricks i can recomend you our new series on our youtube chanel called engineers kitchen
    Best Regards
    Tobias Ritschel
    19.10.2017
    6
    Thank you ritschel93 :-)
    I definitely will try this channel :-)
    By douglasm in forum VSTA
  2. Access to Zenon Library with C/C++?
    By nollh in forum VSTA
    Last Post: 28th July 2015, 14:35
  3. Replies: 2
    Last Post: 10th May 2013, 16:40
  4. Replies: 2
    Last Post: 8th April 2013, 00:28
  5. Combined element and symbol library problem...
    By marduv in forum zenon Supervisor
    Last Post: 28th July 2010, 23:41
