Thread: Interlockings
    30.03.2016
    42
    Default Interlockings
    I have a problem with the interlockings module. It looks like in case that one of the variables is INVALID, The interlock will not work.
    Also what is strange is that the INVALID statusbit is not shown in the uncollapsed list of the statusbit, but you can type it.
    Unfortunately the interlock wil not work.
    What I want is that if a specific RV is IVALID A dialog button must be interlocked. I have added this additional button in the command_processing dialog.
    I use V7.60 SP0
    Please help
    1,038
    Default Re: Interlockings
    While RV is INVALID the command processing does not allow "normal" commands (action buttons are grayed out or not visible at all). While INVALID only 'forced command' (emergency Open) and 'replace' (alternative value / substitution in HMI) actions are allowed.
    To disable additional, your own, dialogs you can link RV (or ConnectionState) variable with a reaction matrix evaluating INVALID/connection loss and then calling a function 'write set value' to some additional, internal, BOOL, network, variable.
  1. Configuring interlockings
    By knubla in forum zenon Energy Edition
    Last Post: 21st November 2012, 11:29
  2. Combined Element Interlockings
    By tantalum in forum Engineering Studio & Service Engine (former zenon Editor & Runtime)
    Last Post: 23rd May 2011, 12:35
  3. Interlockings (Verriegelung)
    By imtech in forum Engineering Studio & Service Engine (former zenon Editor & Runtime)
    Last Post: 15th September 2009, 08:07
  4. Commands interlockings Problem
    By jusufs in forum Engineering Studio & Service Engine (former zenon Editor & Runtime)
    Last Post: 24th August 2009, 00:59
