Thread: IEC61850 Driver - Time Synchronization AML CEL
    11.04.2017
    23
    Default IEC61850 Driver - Time Synchronization AML CEL
    Hello everybody,
    I'm working on Zenon Operator 7.50
    In my project there are two type of 61850 IED device, both can support SNTP synchronization.
    In the pc where Zenon is running the changing of summer time is disabled and time zone is set +00:00.
    In AML and CEL Received Time is correct according single device time (but it can be different to PC time that is not time synchro with devices)
    My questions are:
    1. is possible ignore IEC61850 time stamp and set Received Time according PC zenon time?
    2. if 1 is not possible, zenon can accept SNTP synchronization?
    (any alternatives good ideas to solve the problem?)
    Thank you
    Andrea
    22.03.2010
    18
    Default Re: IEC61850 Driver - Time Synchronization AML CEL
    Hi!
    You should always use the time stamp from the 61850 telegram! In case of a major problem you want to see in which order the events happened.
    zenon uses the system time.
    If it's possible to configure your OS for using SNTP that's a very good idea.
    Fredrik
    839
    ad.1
    The IED61850 Standard does not allow to a client to ignore time stamps delivered by IEDs when IED delivers t-values with valid TimeQuality. So sorry, you cannot force the client to ignore valid time stamps. But if the time stamps coming from IED are wrong, then the IED is obligated to send t-value with ClockFailure flag (then zenon will ignore this external time stamp automatically). If the IED is sending incorrect time values but with TimeQuality = OK - then this IED is not compliant with the Standard!
    ad.2
    Depending on Windows version you may setup in your OS the NTP client:
    1. cmd: gpedit
    2. Local Computer Policy > Administrative Templates > System > Windows Time Service > Time Providers > Configure Windows NTP Client:
    • enabled, IP of time server, etc.
    and make also sure that the Windows service w32time is running (in admin context), e.g. cmd: net start w32time
    Then Windows shall synchronize the clock of the PC with this external time server (as far as the group policy allows it too).
    You may add in Windows registry (regedit) keys to make Windows w32tm write a log:
    HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Servic es\w32time\Config
    i was using:
    FileLogEntries, REG_SZ, 0-116
    FileLogName, REG_SZ, C:\Windows\Temp\w32time.log
    FileLogSize, REG_DWORD, 0x00010000
    This LOG file i was even evaluating in zenon Logic to set in zenon variables with current indication about time synch of my PC.
    There could be also relevant Windows Event Viewer entries in: Event Viewer (local) > Windows log > System
  1. How to display CEL/AML time column in 24 hour format
    By jjplaw in forum zenon Supervisor
    Last Post: 24th February 2013, 07:41
  2. Time synchronization have problem in the alarm list
    By shahramkh59 in forum Drivers
    Last Post: 10th April 2011, 19:19
  3. Time synchronization in reverse direction
    By michael_k in forum zenon Energy Edition
    Last Post: 16th February 2011, 10:33
  4. IEC-870 time synchronization
    By okhotnikov in forum zenon Energy Edition
    Last Post: 27th August 2010, 13:53
  5. IEC-870 time synchronization
    By okhotnikov in forum Drivers
