Thread: Accessing variables in Runtime wizard and service
    08.06.2017
    3
    Default Accessing variables in Runtime wizard and service
    I have been trying to migrate some of the VSTA functionality to the Add-In Framework for Visual Studio 2017 in Zenon 7.60 but I am not sure how to do this.
    I was looking for the same functionality as it was avaliable in the VSTA to access, read/write by variable name like this:
    Code:
    this.Variables().Item("VariableName").set_Value(vindex, value);
    When I try to implement the same functionality in the Add-In Framework using Developer Tools for VS 2017, I cannot find the "Item" object like the one in the VSTA.
    I'm using the IProject context from the Run or Start methods...
    Code:
    IVariablesCollection zVariables = context.VariablesCollection;
    And then i vould like to get the Item by the variable name... zVariables.Item("VariableName");...
    But there is no option to address the variable item by its name. The only method I can see is GetItemById which is not relevant for my use case...
    I also went over all of the examples provided on the github repositories, but I don't find any relevant information about this.
    Can someone please explain what I'm doing wrong... thank you.
    28.02.2013
    159
    Default Re: Accessing variables in Runtime wizard and service
    first make sure to add the variable namespace to your project
    using Scada.AddIn.Contracts.Variable;
    then (if you are using Linq) you get the variable object reference from the VariableCollection
    IVariable myVariable = (from X in context.VariableCollection where X.Name == "YOURVARIABLENAME" select X).First();
    to use Linq include also
    using System.Linq;
    Felix
    Quote Originally Posted by emrocon View Post
    Code:
    Code:
    15.11.2016
    99
    As Felix mentioned: You need to add some references, if you want to access them directly.
    Like:
    using Scada.AddIn.Contracts.Screen;
    In the new API there is no "Item" method anymore.
    You can address these objects just with:
    IScreen myScreen = context.ScreenCollection["Screen name"];
    IVariable myVar = context.VariableCollection["Varname"];
    BR,
    Georg
    08.06.2017
    3
    Thank you both.
    Everything makes sense.
    For some reason my mind was not able to draw parallel between Zenon VariableCollection and C# System.Collections
    It works now.
  1. Rename Variables from VBA Wizard
    By yolovs in forum VBA
    Last Post: 10th April 2017, 10:01
  2. Replies: 0
    Last Post: 18th May 2015, 14:48
  3. Replies: 1
    Last Post: 19th May 2011, 07:51
  4. Replies: 0
    Last Post: 22nd June 2010, 09:02
  5. Replies: 0
    Last Post: 20th August 2007, 13:08
