Thread: search replace variable text
    joulz Gast
    Default search replace variable text
    Im trying to search and replace the following:
    @V401!AWWG401A@@
    by @V405!AWWG405A@@
    search string V401!AWWG401A
    replace string V405!AWWG405A
    zenon does not recognise the search string. Am i doing something wrong
    Can anybody help me
    Im using 6.22 SP1 build5
    Default Re: search replace variable text
    could you please tell where the original text is, you want to replace?
    Is this a limit text or any other text not shown in the detail view?
    Or is this text e.g. the identification or any other text which can be displayed as a column in the detailview?
    I just tried with 6.22 SP1 build 0.
    If this concerns a limit text, you need to right click in the detailview, and choose "replace text in limits" from the context menu, instead of "replace text in selected column" and select the correct limit (limit 1 or limit 2).
    In this case it would probably be sufficient to use "401" as the search string, and "405" as the replace string.
    You can see the preview of the new name in the search & replace dialog.
    joulz Gast
    its in the identification column
    joulz Gast
    its working now
    only replace 401 by 405 was sufficient
    thanks for the fast responce
  1. Picture switch - Replace indices
    By imtech in forum zenon Supervisor
    Last Post: 11th September 2009, 08:35
  2. using a text box
    By beer_klinkhammer in forum VBA
    Last Post: 15th January 2009, 16:37
  3. Limit Text - Display ID or Name of variable
    Last Post: 9th December 2008, 15:23
  4. Global search and replace
    Last Post: 26th November 2008, 08:29
  5. Display Text Value
    By lengele in forum zenon Supervisor
    Last Post: 18th December 2007, 13:50
