Showing results 1 to 7 of 7
Thread: File transfer in zenon-7.5 with IEC_61850
    29.04.2014
    27
    Default File transfer in zenon-7.5 with IEC_61850
    Hello Copadata support,
    I am trying file transfer between an IEC-61850 device and Zenon 7.5.
    Could anyone support?
    Thanks in advance
    28.02.2013
    200
    Default Re: File transfer in zenon-7.5 with IEC_61850
    Hello saravanan1985,
    did you check the driver documentation? (Manual -> IEC850 -> IEC850 client functions -> Filetransfer)
    There is explained in detail, how to configure the command and directory variable to retireve the files.
    Felix
    29.04.2014
    27
    Hi felixst,
    Yes, the manual defined things were done,
    But we need wpf element file. Could you support?
    28.02.2013
    200
    Hi saravanan1985,
    what WPF do you mean?
    The files can be transferred using the !command and !directory variable of the IEC850 driver.
    There is no need for an additional WPF control.
    However, if you are talking about COMTRADE files and you need to display them after the transfer, there is a COMTRADEVIEWER CDWPF that can be downloaded from our website (login needed).
    Is it that what you are looking for?
    Felix
    29.04.2014
    27
    Hi Felix,
    Yes I am taking about same, comtradeviewer cdwpf.
    Could you support for login?
    28.02.2013
    200
    Please go to www.copadata.com and register as user on our website.
    Afterwards you can access the download section to get the cdwpf.
    Felix
    29.04.2014
    27
    Thanks Felix,
    I got it. It works fine
    regards
    sarav
  1. File transfer
    By roberto1978 in forum zenon Energy Edition
    Last Post: 9th August 2018, 11:01
  2. Replies: 5
  3. Transfer RT files
    By nirren1992 in forum zenon Supervisor
    Last Post: 10th March 2017, 08:26
  4. Start Program Transfer Parameter
    Last Post: 4th May 2011, 01:45
  5. How to transfer a Zenon license?
    By willetin in forum zenon Supervisor
    Last Post: 19th January 2011, 11:08
