Thread: Problem with Autotstart project in Straton Runtime Manager
    16.05.2016
    10
    Frage Problem with Autotstart project in Straton Runtime Manager
    The Autostart project (Straton Runtime Manager) does not work on some of my computers.
    Does anyone know if there are any registry setting in Windown 10 that prevent Staton Autostart?
    16.05.2016
    10
    Blinzeln Re: Problem with Autotstart project in Straton Runtime Manager
    It turns out that I can do autostart for Straton RT using .bat file with simple command line:
    start "" "%Zenon_Program_Path%\STRATONRT.exe" PATH=%Runtime_Folder_Path%
    Thank you to my local supplier of Copadata for great tip!!!
    931
    Default Re: Problem with Autotstart project in Straton Runtime Manager
    To be honest i do not know what environment variables in Operating System the STRATON Installer creates. Is this your case?
    The zenon Installer - since introduction of 64-bits systems - creates:
    %CD_PROGRAMDATAxxxx% - provides the path of *.sym, *.xsl, *.frm, ... files; xxxx is zenon version, e.g. 7600=C:\ProgramData\COPA-DATA\zenon760\
    %CD_SYSTEM%  - provides the path to *.ini files, e.g.: C:\ProgramData\COPA-DATA\System\
    %CD_USERDATA% - provides the path to projects, e.g.: C:\Users\Public\Documents\zenon_Projects\
    In versions with only 32-bits (ends with 7.00) there was also an environment variable for program installation directory:
    %CD_PROGDIR% -> directory where zenon is installed, e.g.: C:\Program Files (x86)\COPA-DATA\zenon 7.00 SP0\
    You can list (or create) environmental variables with the command line (cmd) set.
    Simple use/check e.g.: in Windows Explorer you may type %CD_SYSTEM% and the Explorer will open the content of the directory with zenon6.ini and zenProcGateway.ini files.
    Since 32/64 bits systems, if you like to use access to program directory via environment variables of OS, please create on each computer in the Network your own environment variable (on all computers with the same name), with the path valid on the particular PC. Then the .bat file (and/or zenon function 'start application') may refer the %% variables and be the same for all PCs.
  1. SQL problem with zenOn 6.21 - huge project-log file
    By herberto in forum zenon Supervisor
    Last Post: 12th November 2014, 13:22
  2. Project manager window hidden in zenon
    By mattsd in forum zenon Supervisor
    Last Post: 13th September 2010, 04:39
  3. Problem of VSTA after restore project
    By altera in forum VSTA
    Last Post: 22nd June 2010, 14:48
  4. SQL problem with zenOn - huge project-log file
    Last Post: 16th April 2009, 07:07
  5. Project manager problem.....
    By paf in forum zenon Supervisor
    Last Post: 21st April 2008, 13:44
