Thread: IEC61850 Driver - Data Type
    11.04.2017
    23
    Default IEC61850 Driver - Data Type
    Hello everybody,
    I'm working on Zenon Operator 7.50
    In my project I need to connect N devices of same type. Each device is defined in Zenon like 61850 server with different net address.
    I'm using symbolic addressing and the import of variables from driver is working fine.
    I would like to create a datatype, from a list of variables imported by the driver, of device 1 and use it for define variables of other devices.
    (I did the same for modbus driver, I created a datatype starting from a fix position and ,using offset, I created other variables)
    For IEC61850,with symbolic address (var example:EKIP_01!AA1J1Q03A1LD0/XCBR1/Pos/stVal[ST]), I don't know how to create a datatype... now I exported a csv file with variables of device 1, I open it in excel (I changed technical key and net address according device 2..3..4) then I imported it in Zenon. In this way if I have to do some modifications I have to export/import again the list of variables for each device... the best way, I think, is using a datatype.
    Any idea how to create a datatype for 61850 symbolic address variables?
    Thank you
    845
    Default Re: IEC61850 Driver - Data Type
    Oh, i like the way you think
    Unfortunatelly a data type has no property for Symbolic Address, neither there would be a replacement mechanism for string-based properties while creating variables or exchanging the data type. yet.
    So your current attempt - to export in CSV (or XML), replace and import - is probably the best for the moment.
    11.04.2017
    23
    Thank you for your reply
    Andrea
    11.04.2017
    23
    It can be a good improvment for the future
  1. Replies: 0
    Last Post: 1st September 2015, 10:48
  2. Nested Structured Data Type in Combi Element
    Last Post: 21st March 2012, 07:38
  3. 64bit data type in modbus
    Last Post: 12th January 2011, 14:01
  4. How can I read this two type of Data register?
    By michael_k in forum Drivers
    Last Post: 24th November 2009, 16:23
  5. more than one driver of same type
    Last Post: 18th September 2007, 07:36
