Thread: Alarm storing
    28.03.2017
    11
    Default Alarm storing
    Hi, I'm trying to report all the alarms in a plant.
    The AML is working well and I'm reporting in Report-viewer the alarms.
    I can only report alarms in the buffer ring, so as soos as someone resets the alarm, the data about that alarm is lost and it isn't saved in the report.
    I'm looking for the way to store and report ALL the alarms, not only the active ones in the buffer ring.
    I tried to set in project/AML the property "Save AML data" to "ring buffer and historic data" but also with this configuration it doesn't work and I lost not active alarms.
    Thank's for your help.
    22.03.2010
    18
    Default Re: Alarm storing
    Hi!
    Check your filter for the AML dataset. There is a choice between alarmbuffer and historical alarms.
    Best regards
    Fredrik
    28.03.2017
    11
    Quote Originally Posted by fredrik.velin View Post
    Hi!
    Best regards
    Fredrik
    Thank you Fredrik! Fast and clear.
    I succeded in counting my alarms but I need to report the total duration for each alarm.
    Do you have any suggestion? I tried to do something like "Fields!TIMEGOES.Value-Fields!TIMECOMES.Value" in my chart but it doesn't work, is there a simple way to display the duration of my alarms as I did for the counting?
    I attach an example of what I mean, thank you again!
    28.02.2013
    226
    Good Morning,
    you can use the function "datediff" in your expression instead of "-".
    See MS-Technet for details: https://technet.microsoft.com/en-us/library/aa337092(v=sql.100).aspx
    Felix
  1. Storing every value not on change
    By vpartinov in forum Engineering Studio & Service Engine (former zenon Editor & Runtime)
    Last Post: 17th August 2017, 14:42
  2. How can I tell if there is an active alarm in an alarm group?
    By mjackson in forum Engineering Studio & Service Engine (former zenon Editor & Runtime)
    Last Post: 21st April 2017, 14:17
  3. Double Click Acknowledge of alarm on Alarm Screen..!
    By daujivar in forum Engineering Studio & Service Engine (former zenon Editor & Runtime)
    Last Post: 31st August 2016, 07:22
  4. Problems with alarm list and alarm time
    By dario in forum Engineering Studio & Service Engine (former zenon Editor & Runtime)
  5. Alarm Status Line and Alarm List
    By tomaslipa in forum Engineering Studio & Service Engine (former zenon Editor & Runtime)
