Thread: Problem with ICCP Gateway
    24.03.2015
    Default Problem with ICCP Gateway
    Hello, I can't find the Transport Selectors (TSEL) value in the zenProcGateway.INI. Where can adjust that value?
    902
    Default Re: Problem with ICCP Gateway
    The TSEL is currently fix and cannot be changed; it does not have entry in INI file.
    What is the use-case, why the default transport selector is not suitable for you?
    902
    The default TSEL value (for as well ICCP-Client as ICCP-Server) is 00 00.
    Since version 7.60 - from build 54784 on, the zenPG ICCP has additional configuration tab 'advanced settings' were you can setup the OSI parameters: TSEL, SSEL, PSEL, AP Title, AE Qualifier. Note: previously a subset of OSI parameters were configurable via INI file.
  1. Process Gateway
    Last Post: 18th August 2020, 13:52
  2. Proccess gateway
    By yazan in forum Drivers
    Last Post: 3rd November 2016, 13:15
  3. Process Gateway
    By yara in forum Drivers
    Last Post: 4th November 2014, 17:36
  4. User managment Problem, Snapshot relativ Problem
    Last Post: 13th September 2010, 23:06
  5. Process Gateway
