Thread: Is debug is possible in VSTA without stopping the other running macros?
    17.04.2017
    21
    Default Is debug is possible in VSTA without stopping the other running macros?
    In my project i have 10 macros for machine sequence and if i want to edit and debug one macro in online is it possible to do that without stopping of other macros.
    I have tried this but when one macro is running i couldn't able to do this untill running macro is exit.
    Any solution for this in zenon vsta.
    Dhanapal L
    03.11.2015
    35
    Default Re: Is debug is possible in VSTA without stopping the other running macros?
    afaik that is not possible in VSTA, because every macro is in one single class - one single AddIn-object. Debugging means, compiling it in debug mode and stopping when the breakpoint is hit. This stops automatically the execution of further code.
    The other macros do not run in an other process.
    17.04.2017
    21
    Thank you for your reply.
    I need to debug the code which I modified and I don't want to stop other running macros, is there any solution to do this with Zenon vsta?
    Dhanapal.
    03.11.2015
    35
    are the other macros also working with the zenon COM?
    if yes: as far as I know it is not possible to debug one method while other methods, macros or processes, under which context the macro-method is executed, are still running.
    I'm not 100% sure if this is your intendation. But if you find a solution - let me know
  1. Replies: 5
    Last Post: 12th September 2017, 13:35
  2. Debug in Runtime
    By zenmyway in forum VSTA
    Last Post: 29th April 2016, 12:42
  3. Stopping runtime from windows via VBS
    By ruslan_zakirov in forum Engineering Studio & Service Engine (former zenon Editor & Runtime)
    Last Post: 12th January 2016, 12:30
  4. web server stopping
    By jurijcadez in forum Smart Server & Smart Client (former Webserver & Webclient)
    Last Post: 4th June 2013, 08:35
  5. Starting and stopping SNMP drivers
    Last Post: 12th February 2013, 23:12
