Thread: zenDBsrv
    22.12.2016
    8
    Default zenDBsrv
    Hi everyone,
    I tried to restore a project to Zenon Energy Edition 7.50 which was done by a colleague and I wanted to test the driver configuration. However, when I did it, I received the error that it could not establish a connection to the project due to zenDBsrv not running. When I first installed Zenon on this work laptop, I had some problems with the database since there already was a Zenon SQL 2012 Database, but as I recall, I managed to install it correctly and start the runtime and establish a connection to an IED. Some time has passed and I couldn't find zenDBsrv on the services window.
    If anyone could help me find out what the problem is and what I could do to solve it, I'd very appreciate it.
    Thanks,
    Mehrdad
    02.07.2014
    27
    Default Re: zenDBsrv
    Hi mehrdad6687,
    Try to Register files again by clicking "Standard" button in "Startup Tool". Hope this will solve your issue.
    Stani
    22.12.2016
    8
    Thanks for the answer. But I tried this and I could see the zenDBsrv open in processes on task manager but still the service is not open yet and I cannot restore the project. Is it worth to install Microsoft SQL again and try the services?
    I don't want to have to reinstall Zenon since now I have another issue trying to install it on a different windows 10 PC and I keep getting the attached error message. I've made sure the windows is updated completely so I don't know what is the problem.
    Thanks again for the help.
    921
    The errors about mfc-dll are comming because on your Windows you are missing correct Visual Studio Redistributables for 64 and 32 bits (on 64bits system you need to install both). There was some issue in Windows. Unfortunately, I don't remember details anymore (was more as a year ago), maybe some else may add more hints here.
    08.12.2015
    39
    Ursula is right, the missing mfc140u.dll probably means that the Visual Studio redistributable version 2015 is not well installed on your PC.
    There was an issue some time ago, but now it has been fixed by Microsoft. Trying to install the 32 bit version of the Redistributable automatically "removed" the 64 bit version. But this should not happen anymore.
    First of all, if you are running an x64 PC, check in your installed programs that the Microsoft Visual C++ 2015 Redistributables x86 and x64 are well installed. If not, recover it from the Microsoft website or from the zenon CD and install it
    Have a nice day,
    Anthony
  1. Zenon energy edition 7.50 SP0 zendbsrv is not running
    By mehrdad6687 in forum Editor and Runtime Setup
    Last Post: 22nd December 2016, 14:45
  2. Zenon 7 registration error with "ZenDbSrv is running" message
    Last Post: 7th June 2013, 11:47
