Thread: DNP3 communication
    Default DNP3 communication
    I have question about DNP3_TG driver. I want to create communication with RTU (DNP3 Slave) via GPRS TCP/IP. But wap ip address of the outstation is not static. The case is that the slave initiates a session but the master does the polling so Zenon (DNP3 Master) doesn't need to know the ip of the outstation. Is this possible cause in DNP3_TG driver in Outstation settings must be entered the ip address of the outstation.
    Default Re: DNP3 communication
    Hello vpartinov,
    Thanks for the post and welcome to the forum!
    It is an interesting use case which you describe. In a normal case, with only an initiating endpoint, a DNP3 master would attempt to establish (initiate) the connection to the outstation and send class poll requests cyclically to the outstation to retrieve event data.
    A DNP3 master can also be a dual endpoint master with both an initiating endpoint and a listening endpoint. A dual endpoint DNP3 master may initially initiate the connection, send a class 0 poll in order to get the initial values, enable unsolicited responses and then close the TCP/IP connection to the outstation again and wait for the outstation to actively establish the connection and send unsolicited response to the master.
    The DNP3_TG master driver can be configured to have a dual endpoint however it does require a known IP address of the outstation in order to establish a master-outstation association and assign events received as unsolicited responses, to the corresponding connection in the driver and the corresponding points (zenon variables) in the master database. The DNP3_TG master only accepts connection requests on the dual endpoint listening endpoint for IP addresses that are configured as an outstation in the driver configuration.
    Unfortunately, there currently is not a mode of operation supported in the DNP3_TG driver that would fit your use case where there is a listening endpoint only and any TCP/IP connection would be accepted and a dynamic master-outstation association is created where the master would send requests to the (unknown / dynamically created) device.
    Please feel free however, to contact your local zenon representative with more details, for us to see how the DNP3_TG driver could be enhanced to support this operation mode in future!
    Mark, thank you for the information.
    So can it be done with data sim cards with public fixed IP addresses for the outstations?
    Vladimir Partinov
  1. DNP3 Over Serial Port
    By junaid in forum zenon Energy Edition
    Last Post: 8th December 2014, 08:37
  2. Dnp3
    By xeren in forum Drivers
    Last Post: 6th October 2013, 23:52
  3. DNP3 Treiber Frage
    By jusufs in forum Drivers
    Last Post: 30th April 2013, 09:42
  4. Communication problem with DNP3 device
    Last Post: 16th January 2011, 20:49
  5. Process gateway-DNP3
    By rolindo in forum Drivers
