Thread: QR code device
    19.06.2017
    2
    Default QR code device
    Dear all
    I have a question about how is it possible to gathering data from Qr code device to the zenon supervisor Area?
    Is it possible already?if yes, with which drive or protocol it should be done?
    Thank you in advance
    13.08.2013
    57
    Default Re: QR code device
    could you specify your use case?
    We currently have a wizard, Variables->Everywhere Essentials QR Code Generator, which creates QR Code for variables. This QR codes may then be used in the zenon Everywhere App.
    Of course you may also be able to use it to just create QR codes(.png) for variables and use it elsewhere as you see fit.
    Anyway if you want to read some QR code from external source you may do so via the API, propably using an QR code library like https://qrcodenet.codeplex.com/ to write some variables.
    best regards
    Sigi
    21.07.2017
    3
    I don't think they are compatible yet.
    Correct me if I am wrong.
    ______________________________
    Alexandra
    NTT DATA embedded
    18.07.2017
    8
    Quote Originally Posted by sntech View Post
    best regards
    Sigi
    dear Sigi
    First thank you for response.
    second, my scope work is as below:
    in a production line in different parts there are few thin computers which is connected to the barcode scanners. Each barcode shows different specification of the good.
    all these specifications should be shown in scada.
    in these case still it is practical to use API?
    Thanks alot
    15.01.2016
    90
    Hello negin
    Yes it is possible with the API because you can write the data you read from your QR Code to a zenon variable. But you have to do a little programing.
    Tobias Ritschel
    18.07.2017
    8
    Lächeln Re: QR code device
    Quote Originally Posted by ritschel93 View Post
    Hello negin
    Dear Tobias
     Thank you so much for your response.
  1. Interface to KNX device
    By kineaste in forum zenon Network
    Last Post: Yesterday, 15:25
  2. How to change? VBA code -> c# code
    By backjahyun in forum VSTA
    Last Post: 22nd March 2016, 07:46
  3. watchdog for IEC61850 device
    Last Post: 20th April 2010, 23:40
  4. How to get the runtime files on a CE device
    Last Post: 19th November 2007, 13:18
  5. mapping a Networkdrive on a CE device
    Last Post: 19th September 2007, 07:58
