Thread: Whats the "BECKHNG" DynProperty for "Symbolic Address Resolutions"
    02.07.2014
    http://www.kropf-solutions.com/
    3
    Default Whats the "BECKHNG" DynProperty for "Symbolic Address Resolutions"
    Hallo Team,
    i created a "Beckhoff TwinCat NG Driver" (BECKHNG) driver and want to set it to "Symbolic Address Resolutions".
    What is the DynProperty to use? I could modify the data stored in the driver table in the SQL Server. There is a number that flips to 2 when changing the property in the dialog manually. But that not a nice way to do it.
    var driver = project.Drivers().CreateDriverEx(name, "BECKHNG",false);
    driver.OpenConfig();
    driver.set_DynProperties("???????",2);
    driver.CloseConfig(true);
    Thanks,
    Felix
    Ticket-ID [TDE170720YVFM]
    13.08.2013
    57
    Default Re: Whats the "BECKHNG" DynProperty for "Symbolic Address Resolutions"
    i guess you are looking for "SymbAddr"
    best regards
    Sigi
    02.07.2014
    3
    Thanks for the Information.
    I also found "SymbAddr" by digging through .dll and .exe of the driver files, and already tried that, but it always throws a exception:
    Did you had success by trying it? And when yes what version you where using?
    I´m on zenon 7.11 SP0 B37615.
    (edit)
    PS: I know "SymbAddr" for being a BeckhoffNG variable [ED] DynProperty and not a driver property.
    08.02.2017
    13
    I did not try it with the Beckhoff driver, but I guess it will stay the same within the Drivers.
    So may you Can try "DrvConfig.Options.SymbVarName" as your dynamic property path. This was used in zenon 7.60. In zenon 7.11, you may do not Need the "Options" part.
    Btw, you Can check the dynamic properties name with the function "getDynamicPropertyEnum", which returns a string[] with all dynamic properties for a certain zenon item.
    Manual -> Programming
    Interfaces
    -> Objectmodel -> Driver -> Driver-Methods ->
    DynPropertiesEnum[GET]
    BR
    Christian
  1. Replies: 1
    Last Post: 13th March 2017, 13:51
  2. RGM - VBA - ".Save" / ".Read" - change recipe status
  3. Alarmmeldeliste Filter "nicht quittiert" ODER "anstehend"
    Last Post: 31st July 2012, 15:20
  4. "WriteSync" und "PWLevel"
    By rln in forum VBA
    Last Post: 28th July 2011, 07:42
  5. Replies: 5
