Thread: Reading "M" bits in Siemens
    scotttee Gast
    Default Reading "M" bits in Siemens
    Is Driver Object Type "PLC Marker" to be used to read "M" bits in Siemens processors?
    105
    Default Re: Reading "M" bits in Siemens
    Quote Originally Posted by scotttee View Post
    yes to read M-Bits (e.g. M 79.2) you need to use PLC-Marker Object type and BOOL Datatype. In the addressing options you set 79 in Offset and 2 in Bit Number.
    This is for allmost all S7 drivers, e.g. for S7TCP, S7NT, S7HMI...
    Markus
  1. Replies: 2
  2. Replies: 4
    Last Post: 8th April 2009, 09:27
  3. Replies: 5
  4. Replies: 2
  5. "variable image remanent" setting is not saved
