Showing results 1 to 8 of 8
Thread: Password.cmp
    21.06.2017
    Default Password.cmp
    Please help. Zenon Supervisor was hang during loading of software. And error indicated below.
    Error: File "password.cmp" has version number 0.00 SPO- but the project has version number 7.10 SP0.
    15.09.2016
    59
    Default Re: Password.cmp
    if it is possible,try to delete the password.cmp from your Runtime folder and create the Runtime Files again. Dont forget to deactivate the Checkbox for User Administration in Configurate Runtime changeable files
    02.07.2014
    27
    Hello Jack_Alpla,
    try to compile all runtime files again in the zenon editor.
    Is error displayed on an existing site, or you are making a new project in zenon?
    If this is for a new project, I can recommend upgrading to the latest version of zenon.
    Stani
    21.06.2017
    Many Thanks to Stani and Florian. Now its working.
    02.07.2014
    27
    You are welcome! I am glad that we could help!
    03.04.2012
    Italy
    6
    Frage Re: Password.cmp
    Hi all,
    What is the reason / cause that the file "password.cmp" is corrupted without any changes?
    Deleting the file and generating a new one is not an applausible solution.
    I think you need to give us a definitive solutions or the reason for which it corrupts.
    Waiting for your answer.
    Best Regards.
    16.11.2011
    47
    Hello all,
    i have the same problem with the Password.cmp-File.
    It happend twice, the first time i copied the file from a backup.
    What could be the reason for this bug? Nothing was changed and the Project is running since April 2017.
    18.07.2011
    138
    Hi.
    The reason for corrupted password.cmp files is most likely an inappropriate shut down of an IT System. zenon is running on Windows systems, which requires a proper shut down instead of cutting of the power supply. For many machines this is a commonly used way to "switch off" a machine though. This procedure could corrupt files which are currently accessed by the system, also zenon relevant files like Password.cmp
    Our recommendation is always having a system shut down proper, this will avoid issues with corrupted files.
    In the rare case of an unplanned blackout please use the above described way of transferring the compiled Password.cmp file to the target system.
    BR
    Johannes
  1. Error file fpm.cmp in Zenon 6.21 SP1
    By JoCosta in forum Editor and Runtime Setup
    Last Post: 29th November 2016, 16:05
  2. "password.cmp fehlt"
    By michab in forum zenon Supervisor
    Last Post: 8th May 2014, 15:24
  3. Convert runtime created fpm.cmp
    By brc in forum zenon Supervisor
    Last Post: 9th May 2013, 03:25
  4. "file does not exist !" after recovery - files .cmp
    By nbulgarini in forum zenon Supervisor
    Last Post: 10th February 2012, 16:48
  5. Missing .CMP files
    By scotttee in forum zenon Operator
    Last Post: 23rd June 2009, 07:40
