Showing results 1 to 7 of 7
Thread: Interface to KNX device
    13.06.2017
    4
    Default Interface to KNX device
    HI-. I'm Engineer of south Korea.
    I will supply to IKEA (furniture) 2nd Shop to KNX lighting control.
    Use the Zenon 7.60.
    So, I do test it.
    But I have a problem.
    Urgent problem and issue.
    How can I get the KNX db(data base) file in KNX ETS5 or 4?
    am I need this file, EIBv2.DB.dll?
    How can I get the file?
    Thank you.
    BR. I-K. Seo
    From. South Korea
    06.02.2012
    75
    Default Re: Interface to KNX device
    Hey,
    the file you're looking for is the .esf file.
    It can be exported via the OPC export in ETS.
    See here:
    Good luck!
    All the best,
    Xandi
    13.06.2017
    4
    Quote Originally Posted by xandit View Post
    Hey,
    See here:
    Good luck!
    All the best,
    Xandi
    Thank you Mr. xandit
    I know that way.
    But, The OPC export is output the esf files.
    As I attach the capture image, Zenon supervisor can not import the esf file.
    File format supported the *DB format.
    06.02.2012
    75
    I had a short look on my zenon 7.60 (Build 36068).
    On my side it is necessary to import the .esf file, which worked well.
    Do you have a preview version installed or the release version of zenon 7.60?
    Which build version is currently installed?
    All the best,
    Xandi
    13.06.2017
    4
    Thank you, Mr. Xandi.
    I will try again it.
    08.07.2017
    Hi, Could you please help for Ikea here in Australia. I posted before but someone remove it!
    Buy Cafe Lighting furniture online Australia
    24.07.2008
    89
    Quote Originally Posted by lrmaxwell View Post
    Hi lrmaxwell,
    I think I have seen your post - but it didn't include more information than this post you just made, so someone might mistook it for spam.
    In order to avoid this I would recommend you to post a detailed description of your problem. Also I would ask you, to make a new thread if it is a different problem.
    Konstantin
  1. Replies: 0
    Last Post: 7th August 2015, 12:20
  2. EIB KNX communication
    By seb5167 in forum zenon Network
    Last Post: 13th October 2011, 03:13
  3. watchdog for IEC61850 device
    Last Post: 20th April 2010, 23:40
  4. watchdog for IEC61850 device
  5. Mit Java COM-Interface zenOn starten
    By miranda13 in forum VBA
    Last Post: 6th March 2010, 12:46
