Thread: How to modify the column of CSV when using a function - Export CEL
    16.12.2010
    31
    Default How to modify the column of CSV when using a function - Export CEL
    HI All,
    Using a zenon 7.10 supervisor.
    I want to export the CEL data to csv file.
    so, there is the function - export CEL.
    but, the file has tagname and time ...  I need more information (computer name and value).
    How to modify the column of CSV when using a function - Export CEL  ??
    Default Re: How to modify the column of CSV when using a function - Export CEL
    Hi gyu,
    You can define the columns for the CEL export in the project properties, Chronologic event list, Column settings CEL
  1. CEL cyclic export V7.10
    By topo in forum zenon Supervisor
    Last Post: 27th February 2014, 10:01
  2. Auto export of CEL mix up events in export files...
    By ttj in forum zenon Supervisor
    Last Post: 10th September 2013, 07:34
  3. How to display CEL/AML time column in 24 hour format
    By jjplaw in forum zenon Supervisor
    Last Post: 24th February 2013, 07:41
  4. Alignment of Column Headings in CEL and AML
    Last Post: 15th July 2011, 06:45
  5. Variable's name in CEL without the column
    By cyrilfeasy in forum zenon Supervisor
    Last Post: 21st January 2010, 00:57
