Thread: VSTA Editor IN 32 bit Zenon 7.6 Editor
    16.03.2017
    6
    Default VSTA Editor IN 32 bit Zenon 7.6 Editor
    I tried to open VSTA Editor, but the VSTA Editor is not opened in 32bit Zenon 7.6.
    OS: Windows 10, 64 bit
    Zenon Editor: 32 bit
    I tried like this:
    1. Open VSTA Editor with ProjectAddIn...
    2. I selected C#, and clicked OK.
    3. But the editor is not open, and there is no message.
    How can I open VSTA Editor in ZENON 32bit environment?
    I tried the same method in ZENON 7.6 64bit editor, the VSTA is opened.
    But I want to use 32bit ActiveX.
    The 64bit ZENON can not load 32bit ActiveX.
    Thanks.
    Attached Thumbnails Attached Thumbnails VSTA.Editor.01.png   VSTA.Editor.02.png
    13.08.2015
    2
    Default Re: VSTA Editor IN 32 bit Zenon 7.6 Editor
    Hi Monad,
    please check the zenon help.
    There you can find the exact specifications for the 32 and 64 bit versions.
    Manual -> Runtime -> 32 and  64-bit Version
    Manual -> Programming Interfaces
    Helene
  1. Replies: 2
    Last Post: 2nd April 2013, 09:16
  2. Limits in VSTA in ZenOn editor
    By ippela in forum VSTA
    Last Post: 30th August 2011, 14:55
  3. Replies: 1
    Last Post: 30th August 2011, 14:32
  4. Error while loading the VSTA editor-addin
    By jjplaw in forum zenon Supervisor
    Last Post: 24th August 2011, 07:35
  5. Replies: 0
