Thread: creating a table in zenon
    20.03.2017
    6
    Default creating a table in zenon
    Hi all,
    I would like to ask you for some help. How can I create a table (spread list) with configurable columns (let's say it should look like the fragment of a table from Excel) in zenon? What kind of action should I take to do it? I'm a beginner user of zenon so many things aren't obvious for me...
    thanks for your help!
    06.02.2012
    72
    Default Re: creating a table in zenon
    Hi lmucha,
    welcome to the COPA-DATA Forum and thanks for your question!
    I would like to ask which functionality you want to have in this list? Would you like to display archived data? Do you want to change values of variables? Or simplay display process data?
    You may give us a small explenation!
    Cheers,
    Xandi
    20.03.2017
    6
    Hello Xandi,
    thank you very much for your reply.
    I want to display process data but with specific functionality. I'm receiving string variables from Oracle database via ZGW-SQL (SQL Online) module in following format: “AAA;BBB;CCC;DDD”. I want to present those variables in spread-list (excel like) with scroll bar if necessary and possibility to select one line and do some action with it. For example: we get four variables:
    Variable1 = “23452;A1;D2;350”
    Variable2 = “14584;B2;D2;100”
    Variable3 = “77632;A2;D1;350”
    Variable4 = “34820;A1;D1;620”
    Now we want to present them like this:
    Then we select line 3 and click some button. Pressing button we need to know that we have Variable3 selected. Variable format like “AAA;BBB;CCC;DDD” is just example. We can control it so we may change it freely. We tried to adjust Variable Diagnosis functionality but it is way too simple for us.
    cheers,
    Łukasz
    06.02.2012
    72
    Dear Łukasz,
    thanks for your specific explenation.
    A direct connection from zenon to Excel is not supported anymore. We would have the DDE Driver but this Windows connection protocol is very old fashioned and not recommended anymore.
    I had a try few weeks ago with zenon Version 7.50 and Excel 2013 and I didn't get a communication running. It looks like Microsoft canceled such possibilities with newer Excel versions.
    I would suggest you to take a closer look to our three reporting possibilities.
    - Report Generator
    - Report Viewer
    - zenon Analyzer
    Serveral informations and the possibilities can be found in the documentation and on our homepage directly.
    You can also get in contact with your responsible sales department to get several informations.
    Cheers,
    Xandi
    20.03.2017
    6
    Hello Xandi,
    thank you very much for your reply. Actually I managed this problem creating the tables (spreads) as I wanted using Blend for Visual Studio (with WPF elements). I have connection with Oracle Database, you can see it below:
    Now the question is if it is possible to add extra functions like remove or copy the selected item from the table. Do you have any idea how I could do it?
    Thanks in advance for your help.
    cheers,
    Łukasz
    09.06.2018
    Really helpful, Joined from Sydney Australia.
    Buy Maxwell and Williams https://www.aushoppinghub.com/brand/maxwell-williams/ Online Australia.
  1. Display archived data in table
    Last Post: 4th July 2013, 03:15
  2. Recipe table
    By scadavmesnik in forum zenon Supervisor
    Last Post: 6th August 2012, 23:20
  3. Replies: 0
    Last Post: 11th March 2010, 15:59
  4. Language Table Keywords and VBA
    By jhines in forum VBA
    Last Post: 18th September 2008, 14:52
  5. rapidly creating Zenon functions using import/export
    Last Post: 10th January 2008, 10:20
