Thread: How can I tell if there is an active alarm in an alarm group?
    26.02.2014
    36
    Default How can I tell if there is an active alarm in an alarm group?
    In my project I have my alarms grouped into 9 alarm groups.
    I need to have a button change colour if there is currently an active alarm in a specific alarm group.
    For this I need either a BOOL for active alarm in this group yes/no or a value for number of active alarms in the group so I can check if it is > 0.
    How can I do this please?
  2. #
    983
    Default Re: How can I tell if there is an active alarm in an alarm group?
    i suppose it may work only if you will use Areas instead Groups; or the same variables will be in a particular group and in particular area.
  3. #2
    15.09.2016
    61
    You can do this with Alarm Areas.
    You can link the needed groups to the area. it is possible to say that a Byte variable changes its Value if there are any unquitted or active Alarms of a Group.
    Then you only need to create a Limit which changes the collor if the Byte Variable is greater than 0.
    Sorry for my English i hope you understand everything.
  4. #3
    26.02.2014
    36
    I have made an alarm area, but I can see only how to link an alarm class to the alarm area, not how to link an alarm group which is what I need.
  5. #4
    983
  6. #5
    26.02.2014
    36
    That works, I can make an alarm area for each group and put each alarm into both group and area. Thank you.
  1. Double Click Acknowledge of alarm on Alarm Screen..!
    By daujivar in forum zenon Service Engine Supervisor
    Last Post: 31st August 2016, 07:22
  2. More than one alarm in Alarm status Line
    By sudhee in forum zenon Service Engine Supervisor
    Last Post: 21st November 2014, 14:52
  3. Set variable alarm group
    By davide.galigani in forum VBA
    Last Post: 11th June 2014, 19:42
  4. Problems with alarm list and alarm time
    By dario in forum zenon Service Engine Supervisor
    Last Post: 9th November 2012, 13:52
  5. Alarm Status Line and Alarm List
    By tomaslipa in forum zenon Service Engine Supervisor
    Last Post: 21st January 2009, 12:02
