Thread: Rename Variables from VBA Wizard
    09.05.2013
    52
    Default Rename Variables from VBA Wizard
    Dear all,
    I am using zenon Supervisor v7.50 SP0.
    Is there any way to rename variable from VBA Wizard?
    ModifyVariable method can not do that!
    Best reagrds,
    Svetozar Yolov
    09.05.2013
    52
    Default Re: Rename Variables from VBA Wizard
    Deal All,
    Just succeed to rename variable from VBA.
    Here is an example:
    Dim zPRJ As Project
    Dim zVariable As Variable
       Set zPRJ = MyWorkspace.ActiveDocument
        Set zVariable = zPRJ.Variables.Item("SMI_Raw_Fault_0001")               ‘ old var name
        zVariable.Name = "SMI_Raw_Fault_0002"     ‘ new var name
       Set zPRJ = Nothing
        Set zVariable = Nothing
    best regards,
    Svetozar Yolov
  1. How to create a wizard to copy functions while replacing the variables linked in it
    By nishranth in forum Engineering Studio & Service Engine (former zenon Editor & Runtime)
    Last Post: 18th May 2015, 14:48
  2. VBA Wizard
    By perschke in forum VBA
    Last Post: 17th January 2012, 23:34
  3. VBA Wizard Zuordnungen
    Last Post: 14th July 2011, 12:32
  4. Replies: 0
    Last Post: 22nd June 2010, 09:02
  5. Replies: 2
    Last Post: 21st April 2010, 12:43
