Thread: Configuration of IEC60870-5-101/104 Driver in SICAM 230
    01.12.2016
    Default Configuration of IEC60870-5-101/104 Driver in SICAM 230
    This is probably a "newbie" question, but I am unable to find any information on how to configure the IEC 60870 driver (Siemens IEC60870-5-101/104 (AKServer) Driver) in SICAM 230 version 7.20 SP0 Build 24121. Is there a manual, help or anything describing how to set up this driver? The only reference I can find in the documentation is related to the Process Gateway, but this requires a separate license...
    The image below shows that it is possible to add a driver. Adding variables is also possible, but configuration of the driver is not possible.
    916
    Default Re: Configuration of IEC60870-5-101/104 Driver in SICAM 230
    The AK-Driver is developed and documented by Siemens, not by COPA-DATA. If there is no Help for this driver in your SICAM230 installation then please contact the SICAM Support.
    28.02.2017
    5
    check in folder C:\Program Files (x86)\SIEMENS\SICAM 230 7.20 SP0\HELP\ENGLISH\Driver
  1. IOA addressing issue with IEC60870-5 104 driver in zenOn
    Last Post: 28th January 2016, 10:57
  2. Normalized value with IEC60870-5-101/104
    Last Post: 22nd January 2016, 11:38
  3. Normalized value with IEC60870-5-101/104
    By markclemens in forum Drivers
  4. IEC 61870-5-104 driver for SICAM 230 SP1
    By kirca in forum zenon Energy Edition
    Last Post: 22nd August 2011, 15:04
  5. IEC 61870-5-104 driver for SICAM 230 SP1
    By kirca in forum Drivers
