Thread: How can I get an element at VSTA Runtime?
    16.03.2017
    6
    Default How can I get an element at VSTA Runtime?
    In VSTA Workspace, I can get static text property.
    like this:
    [System.AddIn.AddIn("MyWorkspace", Version = "1.0", Publisher = "", Description = "")]
    zenOn.IDynPicture scr = this.ActiveDocument.DynPictures().Item("Dashboard");
    zenOn.IElement Text = scr.Elements().Item("Static text_1_2");
    string textProp = (Text.get_DynProperties("Text")).ToString();
    BUT, how can I get static text property at RunTime(Project VSTA)?
    The below code throw exception: textProp is null
    [System.AddIn.AddIn("ThisProject", Version = "1.0", Publisher = "", Description = "")]
    zenOn.IDynPicture screen = this.DynPictures().Item("Dashboard");
    zenOn.IElement text = screen.Elements().Item("Static text_1_2");
    string textProp = (text.get_DynProperties("Text")).ToString();
    OR, Could I use "this.ActiveDocument" at runtime VSTA?
    Thanks.
    03.11.2015
    46
    Default Re: How can I get an element at VSTA Runtime?
    Hi Monad,
    please note that there are quite many DynamicProperties which can only be modified/adjusted in the editor but not during the runtime.
    If you debug through your code, do you get the correct text-instance back? If this is the case, the text property might not be available in the runtime.
  1. How can I use element in VSTA?
    By youngseolwha in forum VSTA
    Last Post: 7th March 2016, 08:14
  2. Replies: 3
    Last Post: 23rd October 2013, 17:10
  3. Movable element in Runtime
    By focus in forum zenon Supervisor
    Last Post: 7th February 2012, 09:48
  4. Replies: 1
    Last Post: 19th January 2012, 00:01
  5. Replies: 1
