Thread: VSTA Disapears
    11.04.2008
    40
    Böse VSTA Disapears
    We have some VSTA code in VB.Net and during commissioning and doing some modifications and debugging All the VSTA code has disappeared.
    The only way we can get it back is from an old backup which is not good.
    Graham
    03.11.2015
    48
    Default Re: VSTA Disapears
    Hi Graham,
    I'm sorry to hear that. Have you checked or backed up older runtime files? Usually VSTA creates a vsta.zip file in the "RT\FILES\zenon\system" directory. If there are older Runtime Files available, you might be able to get the code back either bei extracting the zip contents or copying it back to the Editor directory (Database-ID\FILES\zenon\system). Which modifications were done when this issue appeared?
    Is VSTA still starting in VB.Net context or does it start with C#?
    08.02.2017
    13
    there is also a vstaorig.zip file in the runtime folder. If the runtime was not restarted/reloaded, you may find your Code in ether the vsta.zip or the vstaorig.zip file.
    BR
    Chris
    11.04.2008
    40
    It still opens in VB.Net.
    I'll have to take a look at older runtime backups.
    We are back up and running now, but it was strange that it did it. We had been doing quite a few edits on graphics and VB.net so its hard to say what caused it.
    Graham
