Thread: How to get a current value of variable that not displayed in the runtime.
    16.12.2010
    31
    Default How to get a current value of variable that not displayed in the runtime.
    Hi, All
    i am using a zenon 7.10.
    I want to get a current value of variable via vba.
    I found it in the manual.
    var_val = thisProject.Variables.Item(i).Value
    It can get a value of variable when display in the runtime (screen).
    but, no data when the variable is not displayed in the runtime.
    So, I need " how to get a current value of variable that not displayed in the runtime via VBA ".
    29.07.2007
    Germany
    191
    Default AW: How to get a current value of variable that not displayed in the runtime.
    you will find more then 'var_val = thisProject.Variables.Item(i).Value' in the manual.
    Direct VBA read access on variables is only possible if the variable has been registered in the driver (advised) and if it has a value, i.e. if IsOnline() is true . Simple spontaneous queries (requests) are no longer possible.
    The following functions of the “Variable” object return an error if this is not the case:
    Value
    StatusValue
    StatusExtValue
    StatusString
    LastUpdateTime
    LastUpdateTimeMilliSeconds
    This means that existing projects will no longer run in the Runtime after the conversion, as the functions mentioned above will fail.
    Possible solutions:
    Define an online container for all affected variable accesses.
    Advantage: The variables will only be requested if you really need them.
    Disadvantage: Increased programming effort.
    Set the option “DDE active” in the group “Additional settings” of the variable properties for all affected variables.
    Advantage: Easy to perform.
    Disadvantage: The driver continuously requests all variables.
    So hope the help helps
    HP
    string zenon = "7.60 Build52515 / 8.00 Build52082";
    string Windows = "7 / 10 / 2012R2";
    16.12.2010
    31
    Default Re: How to get a current value of variable that not displayed in the runtime.
    Thanks for your kindly reply.
    I tried what you suggested.
    1. Set the option “DDE active” in the group “Additional settings” of the variable properties for all affected variables.
    => does not work.
    2.
    I tried it as follow code.
    Dim WithEvents zOLV As OnlineVariable
    Const strOLV As String = "MyOnlineVariableContainer"
    'initialize event on runtime startup
    Private Sub Project_Active()
       'get object if already exists
       Set zOLV = thisProject.OnlineVariables.Item(strOLV)
       If zOLV Is Nothing Then
          'if not exitst, create a new OnlineVariable container
          Set zOLV = thisProject.OnlineVariables.CreateOnlineVariables( strOLV)
          'add variables to the container
          zOLV.Add "Variable1"
          zOLV.Add "Variable2"
          zOLV.Add "Variable3"
       End If
       'activate 'VariableChange' event
       zOLV.Define
    'event is fired when a variable value changes
    Private Sub zOLV_VariableChange(ByVal obVar As IVariable)
       Dim vValue As Variant
       vValue = obVar.Value
       'ignore error values (i.e. on startup)
       If IsError(vValue) Then Exit Sub
    Debug.Print obVar.Name & " = " & vValue
    'release objects on closing the runtime
       'deactivate 'VariableChange' event
       If Not zOLV Is Nothing Then zOLV.Undefine
       Set zOLV = Nothing
    but, it can get a value when value change.
    I need a current value anytime via vba.
    one more question, while trying,
    it can get a value when display the runtime.
    which means,
    it work when  "" zVariables.IsOnline = 1 "" I think.
    so, I did
    Dim zVariables As Variable
    Set zVariables = thisProject.Variables.ITEM("Test_Val_15")
    zVariables.IsOnline = "1"
    zVariables.IsOnline = True
    but, it does not work.
    is it possible to make the value "true" to work ??
  1. Alarm message compare with current Date
    Last Post: 17th November 2014, 13:24
  2. Sending current values via e-mail
    Last Post: 17th February 2014, 09:30
  3. Current user in header section of the project
    Last Post: 31st July 2013, 10:02
  4. Variable set is not variable being displayed
    By smurfy in forum zenon Supervisor
    Last Post: 22nd February 2012, 04:00
  5. zenOn is not displayed on two monitors
    Last Post: 8th November 2007, 14:03
