Thread: change Linecolor or Fillcolor of a status defination (representationpropertie) with VBA
    30.03.2016
    39
    Default change Linecolor or Fillcolor of a status defination (representationpropertie) with VBA
    Is it possible to change the Fillcolor or LineColor of a Status definition via VBA.
    We have some baytype symbols and the onlything what is different is the color. (10kV/25kV150kV) each voltage have own color.
    My Idea is to reduce the number of symbols. The color will be changed (VBA) when the display is called. for example one display for 50kV one for 25kV
    The line colors is no problem we can export the color property. but with representation of symbol from library it looks that it is not possible.
    any ideas ??
    Thanks in advance
    10.12.2007
    260
    Default AW: change Linecolor or Fillcolor of a status defination (representationpropertie) with VBA
    I would suggest to do this another way. Create an internal variable 'Voltage' UINT or something. Create a Rema for this variable that has the different colors needed (e.g. 10=yellow, 25=orange ...) and use this variable in the symbols as dynamic color variable. Then you only have to set this variable to the right value when switching to a picture. This can be done without the use of VBA.
  1. How to change? VBA code -> c# code
    By backjahyun in forum VSTA
    Last Post: 22nd March 2016, 07:46
  2. RGM - VBA - ".Save" / ".Read" - change recipe status
  3. How to change ComboBox Entires with VBA
    By matthias.zoellner in forum VBA
    Last Post: 8th June 2011, 10:34
  4. Change RtFunctions parameters in VBA
    By kicker in forum VBA
    Last Post: 17th February 2010, 11:05
  5. Change variable status
    By brada in forum VBA
