Thread: IEC62056 / TCP/IP problem
    28.02.2017
    5
    Default IEC62056 / TCP/IP problem
    I use SICAM 230 and need to read data from energy meter ISKRAEMECO MT830 over IEC1107 (IEC62056) TCP/IP. I can connect to the device using telnet and I have ISKRAEMECO software installed and it is connecting to the meters like this:
    I edited file named Treiber_EN.xml adding IEC62056 driver like this:
    Driver settings are these:
    I read the driver help file and found that register address must be in filed "Identification", but my variable options have field IEC62056 address so i tried both ways with no luck. My variable looks like this:
    When the network is NOT connected i have error "TCP connect failed" in Diagnosis Viewer and when network is connected error goes to "Invalid Answer. Timeout Reached" so i guess that TCP connection is established but there is something wrong in mu variable parameters:
    Port 2010 is open in Firewall. Help needed.
    Best regards
    06.02.2012
    72
    Default Re: IEC62056 / TCP/IP problem
    Hi hm123,
    are you still struggling with this topic?
    One thing which came into my mind is to remove the device address completely from the driver configuration.
    I once had an issue where this solved the problem.
    It may worth it to try.
    All the best,
    Xandi
  1. command using Modbus TCP/IP
    By ziadnajjar in forum Drivers
    Last Post: 21st February 2018, 11:15
  2. S7 TCP-IP simulation
    By tihomir in forum zenon Energy Edition
    Last Post: 18th April 2013, 16:22
  3. TCP/IP Comm problem
    By scotttee in forum Drivers
    Last Post: 6th October 2009, 13:16
  4. TCP ports in use by zenOn
    Last Post: 23rd August 2009, 23:18
  5. Replies: 1
    Last Post: 1st December 2008, 10:16
