Thread: Does this pop up msg can caused startup fail to boot up?
    28.02.2017
    3
    Frage Does this pop up msg can caused startup fail to boot up?
    Does Zenon Runtime pop up msg (As per attachment) can causing startup fail?
    15.01.2016
    92
    Default Re: Does this pop up msg can caused startup fail to boot up?
    This message doesnt come from zenon its a security feature of windows so as long you dont click no it shouldnt interupt the start of the runtime
    best regards
    Hi lim hui sin,
    This message should not appear when you start the application normally. When you explicitly start the application as an administrator, this message may appear.
    The zenon editor and the zenon runtime do not require administrator rights and run in a standard user context.
    In fact, the application may not interact with other components correctly, when it is explicitly started as an administrator. For example when you start the zenon runtime as an administrator and an OPC client on the same machine in a standard user context without elevation, the OPC server, started in the user context of the OPC client, will not be able to access the runtime running in the same user context but with elevated privileges.
    28.02.2017
    3
    Quote Originally Posted by ritschel93 View Post
    best regards
    Dear Ritschel93,
    Thanks you for feedback. Appreciates its.
    Am not so familiar with SICAM 230 system and will learn more about that soon.
    Thanks you
    Regards
    LimHuiSin
    28.02.2017
    3
    Hi lim hui sin,
    Dear markclemens,
    Thanks you for detail explanation, it's very useful information for me.
    Am now still learning SICAM 230 system. (Substation)
    Thanks you again
    Regards
    LimHuiSin
  1. [Error ]Zenon not boot images of the Supervisory
    By Leno in forum zenon Operator
    Last Post: 10th October 2016, 07:07
  2. Re: Pop up screen
    By prokopjev in forum zenon Supervisor
    Last Post: 4th October 2013, 06:33
  3. Error Msg -Unlock Project from zenDB Admin
    By daujivar in forum zenon Supervisor
    Last Post: 23rd May 2013, 01:17
  4. Pop up screen
    Last Post: 27th November 2012, 09:52
  5. delay in I-bit when the Communication fail occure
    By shahramkh59 in forum zenon Network
    Last Post: 6th April 2010, 22:48
