Thread: Zenon up gradation from 7.0 to 7.50
    18.02.2017
    6
    Default Zenon up gradation from 7.0 to 7.50
    Dear Support,
    Can you please help out in up gradation of my running system from 7.0 to 7.50. I am having project running on zenon ver 7.0 but for more features i want to upgrade my system to 7.50 without disturbing my previous system. so can you please guide me over the same.
    Vivek
    02.07.2014
    27
    Default Re: Zenon up gradation from 7.0 to 7.50
    Hi gadre14
    You can install zenon 7.5 on the same PC as zenon 7.0. Use the zenon startup tool to change between the two versions, so everything is registered correctly.
    You can convert your 7.0 projects into zenon 7.5, by restoring a project backup or
    restoring a workspace backup.
    Stani
    18.02.2017
    6
    Dear Stani
    Thanks for your reply i had done the same and now project is running on Zenon 7.50. But i am facing one issue after upgradation that is my login functions are not working as it was working in my same project while running on Zenon 7.00.
    Can you guide me over the same.
    Thanks once again.
    Regards
    Vivek
