Thread: Zenon v7.20 unable to communicate with S7 1200
    09.01.2017
    17
    Default Zenon v7.20 unable to communicate with S7 1200
    Hi i am trying to comunicate with the PLC 1200 and i cant what should i do?
    06.02.2012
    72
    Default Re: Zenon v7.20 unable to communicate with S7 1200
    Hey,
    have you already checked out our zenon documentation?
    There is a full topic about error analysis for the S7TCP driver.
    You can find it here:
    Hope this can help you a bit further!
    Good luck,
    Xandi
    Attached Thumbnails Attached Thumbnails 2017-02-24_09h17_47.png   2017-02-24_09h18_50.png
    09.01.2017
    17
    But i got no error it just doesnt comunicate, can you help me another way?
    also this is the version of the software supporteed to zenon ? tia portal v13 sp1 up 4
    15.11.2016
    99
    Hi
    When using the S7TCP32 driver for communication with an S7-1200 or S7-1500 the Remote TSAP has to be set to 02.01.
    -> this should fix your communication issue.
    The "S7 driver for S7-1200 and S7-1500" also known as S7TIA driver was added to zenon 7.20 after release, which means you need a newer Build version to have it.
    BR,
    Georg
    09.01.2017
    17
    ##SOLVED## Thanks
  1. zenon unable to connect to S7-1200
    By misbah in forum Drivers
    Last Post: 17th June 2018, 13:54
  2. zenon logic doesn't communicate with external variables in zenon
  3. Re: zenon logic doesn't communicate with external variables in zenon
  4. IEC61850 to Communicate
    By gyu in forum zenon Energy Edition
    Last Post: 5th July 2013, 06:25
  5. IEC61850 to Communicate
    By gyu in forum Drivers
