Thread: Extended Trend - can't change the columns
    26.02.2014
    36
    Default Extended Trend - can't change the columns
    Hello, can someone help me. I have Zenon 7.50 SP0 and I have an extended trend screen. I wish to edit the function that opens the screen so I can remove some columns. I get the selection window and the first tab "Data". There are columns: Curve Name, Title, Color etc. and I can remove them with right-click and "column selection" or "remove selected columns". Then I click OK to close the popup. However when I open the function again, any changes I made to the columns are undone and they are back to before. Is there a way to make the changes permanent?
    09.03.2011
    40
    Default Re: Extended Trend - can't change the columns
    Hi mjackson,
    To make these changes permanent, you should go, on the function to switch to an ETM screen, to the Tab "Column settings" --> "Expanded curve list"
    See attached screenshot
    Steffi
    26.02.2014
    36
    Thank You.
  1. extended trend options
    By kasimosman in forum zenon Supervisor
    Last Post: 21st February 2014, 15:23
  2. Extended trend with opc-variable
    By robcha in forum Drivers
    Last Post: 17th October 2012, 09:17
  3. Extended Trend parameters
    By fabio79 in forum zenon Supervisor
    Last Post: 5th September 2012, 13:41
  4. Extended Trend HD Depth
    Last Post: 10th May 2011, 23:36
  5. Questions related to Extended Trend
    Last Post: 10th April 2011, 16:37
