Thread: Interlocking teks
    30.03.2016
    39
    Default Interlocking teks
    Hello
    I created an Interlock for additional controlbutton in commandprocessing display. For every Interlock you can set the Interlocking tekst.
    I expected to see the interlock text in the same Interlocking tekst indication in the Commandprocessing dialog. Whenever you click on de button in case the control is interlocked.
    Is My expectation correct?
    The Interlock text used in the Command processing are displayed correctly
    986
    Default Re: Interlocking teks
    I'm not sure if i understand the question. Are you asking about general Interlocking - the node in Editor available also without Energy Edition, e.g. Supervisor: project tree - 'Interlockings'?
    Hmm, interesting: the info in context help of this property could be wrong. In my Editor i see that two properties - in general Interlocks and that by action - have the same name and documentation ID. I'm sorry for that documentation mistake. The text defined in a general interlocking condition is not displayed in command screen control element 'Interlocking Text'.
    Using general interlocking you may protect a dynamical screen element on any screen in zenon, e.g. you can make any button to be displayed greyed out and/or with padlock symbol in the corner. This will also work on buttons in command screen - if linked there.
    The setting for representation of general interlocks are in: project name - 'Graphical design' - 'Locked/Interlocked elements', but the text is probably only for access via API (VBA/VSTA).
    Last edited by ursulak : 20th February 2017 at 10:25 Reason: claryfied documentation issue
    30.03.2016
    39
    Hmm, interesting: the info in context help of this property could be wrong. In my Editor i see that two properties - in general Interlocks and that by action - have the same name and documentation ID. I'm sorry for that. I don't think that the text defined in general interlocking conditions would be displayed in command screen control element 'Interlocking Text'. If yes, then would be a feature i haven't known. I have to research...
    Yes I meant the general interlock.
    how can I access the interlock text via VBA.
    Thanks in advance
    986
    I've never used and is not particularly "Energy". Maybe try to ask in VBA treads.
    Hi ursulak,
    Is there any ways to change the width of the interlocking text or hide any column in Control elements (Interlocking List) of Command Processing. I cannot find this..
    Thank you,
    986
    The possibility to change column settings (width, filter etc.) are coming in 7.60 - we are introducing new, smarter, control element for 'Interlocking List'. The old one (having fix columns) will be there of compatibility reasons. Thus - after you update zenon version to 7.60 - the existing command screens will still use the old control elements, but then you may in Editor simple delete old controls and on the same places on screen create the new. New created command screens (e.g. from templates) will per default use new controls.
  1. Event and interlocking in ALC
    By roberto1978 in forum zenon Energy Edition
    Last Post: 28th January 2016, 11:13
  2. Problem with interlocking
    By knubla in forum zenon Energy Edition
    Last Post: 1st February 2013, 09:33
  3. Create an interlocking
    By davide.galigani in forum VBA
    Last Post: 9th July 2012, 11:20
  4. Interlocking: Value not available
    By sstoilov@gmail.com in forum zenon Service Engine Supervisor
    Last Post: 8th June 2012, 00:42
  5. ALC interlocking
    Last Post: 7th October 2009, 08:44
