Thread: Web Client - Visible Scrollbar on Internet Explorer in full screen mode
    10.02.2015
    47
    Default Web Client - Visible Scrollbar on Internet Explorer in full screen mode
    I'm using a PC (W10) as Web Client.
    In full screen mode, there are scroolbars on the right and on the bottom of the screen.
    I want to remove them.
    STEP1- I opend Zenon6.ini and I configured ScreenProfile="Standard_1_m" where Standard_1_m is screen profile (1919x1079) defined in Zenon Project but situation remains the same. It seems even if I change resolution in screen profile, Runtime in web client doesn't respond to the changes.
    STEP 2- I also modified ZOOM = 1 parameter in glob_var.js in wwwroot - zenon folder ( I don't remember if this is the correct path but I'm sure I changed Zoom parameter) to adapt Runtime to the screen but nothing has changed.
    Someone could help me? I would to open Runtime in full screen mode without any scrollbars in the screen.
    Thanks.
    Steven Costantini.
    Steven Costantini
    15.11.2016
    106
    Default Re: Web Client - Visible Scrollbar on Internet Explorer in full screen mode
    Hi Steven,
    Unserstanding how screen resolution and screen plofiles work with WebClients can be difficult:
    - The Screen Profile (set Monitor Resolution) is not considered in the WebClient.
    -> Thats what the ZOOM setting is for.
    -> But his setting usually does not get you the desired result.
    - On the WebClient the size of the ActiveX Element in the browser is the "screen-resolution" for the project.
    A consistent way to get rid of the scrollbar is to change the zoom option in which the WebClient page is opened:
    - this is configured in the initcode.js: "C:\inetpub\wwwroot\zenon\config\initcode.js"
    - The bottom part descriibes the settings for opening with IE.
    -> Setting it to 110% usually achieves the desired result:
    document.write (' width=110%');
    document.write (' height=110%');
    Just refresh the WebClient to see the difference.
    Hope this helps.
    BR,
    Georg
  1. Web server client, blue dots when connected via internet
    By JamesPressure in forum zenon Network
    Last Post: 31st May 2016, 07:59
  2. Internet-Explorer ActiveX Objekt
    By rabi in forum zenon Network
    Last Post: 20th March 2015, 10:06
  3. Access to Symbol in Full Screen mode
    By pilzfrance in forum zenon Supervisor
    Last Post: 26th February 2014, 15:30
  4. zenon Web-Client 7 -> Web-Server 6.22 slow startup
  5. Internet Explorer 8.0 for Web-Client ?
    By lephis in forum Webserver/Webclient
    Last Post: 3rd June 2011, 06:34
