Thread: Connect to Zenon under Windows 10
    Default Connect to Zenon under Windows 10
    Hello collegues
    I can't connect to Zenon Runtime ana Editor from my application.
    I use verson 7.11 build 19245 and v7.50 build 28116.
    I use code like this which work fine under Windows 7.
    private void GetApplicationInterface()
    // Check if zenOn is registered in the ROT.
    try
    zenOn.Application rt = Marshal.GetActiveObject("zenOn.Application") as zenOn.Application;
    if (rt != null)
    zenOn.Projects proj = rt.Projects();
    string name = proj.Item(0).Name;
    catch (Exception ex)
    I tryed to start ZenonRT as Administrator but it didn't help.
    I don't use ZenonRT as service.
    Does ZenonRT register into ROT under Windows 10?
    Where can be a problem?
    03.11.2015
    57
    Default Re: Connect to Zenon under Windows 10
    Hi altera,
    you can check if the zenOn.Application object is correctly registered in the ROT by using a ROT Viewer (e.g. RotView).
    Usually the zenon runtime is registered as "zenOn.Application" also in Windows 10 and the example code you sent should work.
    Can you check if the application is registered correctly?
    When do you execute the code? It takes a while until the RT has registered into the ROT
    Thank you.
    It realy works. I started Zenon as Administrator and my aplication is also needed to start as Administrator.
    03.11.2015
    57
    Hi altea,
    so your code successfuly connects to the runtime now, or is there still an issue?
    BR,
    Joris
    Hello Joris
    I could connect to ZenonRT, thank you.
  1. zenon unable to connect to S7-1200
    By misbah in forum Drivers
    Last Post: 17th June 2018, 13:54
  2. zenon7 can't connect with sql on my pc
    Last Post: 8th June 2012, 00:57
  3. Connect VBA to Oracle
    By nblanquart in forum VBA
    Last Post: 9th July 2010, 19:41
  4. Replies: 1
    Last Post: 1st December 2008, 10:16
