Page 2 of 2 FirstFirst 1 2
Showing results 11 to 12 of 12
Thread: Cannot open project
  1. #11
    20.07.2020
    Default Re: Cannot open project
    Thanks, mst and EdgarsFeldmanis!
    Just had the same problem and solved it by
    manually starting the following services: SQL Server (Zenon_2017) ; SQL Server (ZA3) ; and zrsLicSrv.
    For some reason these services are not starting automatically, but it solved the problem.
    Érick Guedes
  2. #12
    09.06.2021
    Daumen hoch Re: Cannot open project
    Quote Originally Posted by EdgarsFeldmanis View Post
    Sorry, for not getting back sooner - got carried away in work.
    Although the problem keeps occuring from time to time I managed to solve it thanks to the solution provided by Mst. The problem was indeed related to SQL server not workng properly.
    What I did was open Services -> find SQL Server (Zenon_2012) -> right click and Start. After restarting the application everything started up normally and worked without problems.
    Thanks alot!
    Same problem happened to me and resolved with your solution.. Thanks a lot
  1. Replies: 2
    Last Post: 24th July 2015, 05:13
  2. Re: The web client does not open the zenon project...
    By sidramsatyal in forum Smart Server & Smart Client (former Webserver & Webclient)
    Last Post: 18th September 2013, 23:23
  3. Replies: 1
    Last Post: 25th July 2013, 11:07
  4. Replies: 12
    Last Post: 25th November 2010, 10:54
  5. The web client does not open the zenon project...
    By shahrzad in forum Smart Server & Smart Client (former Webserver & Webclient)
    Last Post: 8th October 2008, 13:32
