Thread: Process Gateway - Modbus slave - Addressing details
    29.04.2014
    27
    Default Process Gateway - Modbus slave - Addressing details
    Hi All,
    Is it possible to configure 10 Inputs with register address as 2100(example) with bit reference varying from 1 to 10. If Yes where to feed those bit reference in process gateway.
Name:	Process gateway modbus slave.JPG
    regards
    saro
    846
    Default Re: Process Gateway - Modbus slave - Addressing details
    The addressing area of holding registers in a MODBUS protocol bases on WORD. Thus one offset in Process Gateway MODBUS Slave responds in zenon one variable, best choice INT or UINT.
    You may calculate the value of the variable from values of few other BOOL variables using VBA (then store result in an Internal variable) or zenon Logic (then for result use stratonNG variable).
    29.04.2014
    27
    Thanks ursulak.
    I gone for zenon logic.
    846
    zenon Logic supports access to single bits of variables. Thus to change the value of particular bit of an numerical stratonNG variable you may use following ST-language syntax:
    myResult.0 := G202_B213_ALG15; //lowest bit
    assuming that G202_B213_ALG15 is your process variable in zenon, with data type BOOL and set to be 'external visible'.
    And do not forget to create in Logic the 'Logic to SCADA connection' fieldbus driver.
  1. Modbus Process Gateway
    By avinash.malli in forum Drivers
    Last Post: 16th February 2016, 11:14
  2. Modbus Process Gateway
    By hussaini in forum Drivers
    Last Post: 12th November 2015, 14:08
  3. Process gateway Modbus
    By archie in forum Drivers
    Last Post: 13th November 2014, 07:21
  4. Modbus Process Gateway
    By navaneet in forum Drivers
    Last Post: 19th June 2014, 07:47
  5. Replies: 1
    Last Post: 1st April 2013, 22:28
